Author Topic: IT250K Head  (Read 1241 times)
Offline Tossa
IT250K Head
« on: June 19, 2017, 05:45:32 PM »
Took the bike out for it's fiorst run, blew the head gasket, not happy
On inspection of the head it has 5 studs and a bolt at the rear of the head.  My parts catologue shows there to be six studs in the head not 5 and a larger  8mm bolt.
Can anyone explain?
Also torque settings for the studs and larger bolt
Barry
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
Re: IT250K Head
« Reply #1 on: June 19, 2017, 05:51:49 PM »
my money is on a stripped stud and fixer bolt....on Saturday night before a ride....you may need to strip her down and check the case thread...the bolt may have been just a tad too long allowing the head gasket to escape ???
Offline Tossa
Re: IT250K Head
« Reply #2 on: June 19, 2017, 06:09:00 PM »
found a stud not tightened next to the bolt.  But now just looked at the bolt you spoke of and yes it has been cut down (badly) to fit and has a different pitch on the thread to a normal metric bolt, also has flat washer and spring washer on it.!!!!!!!
Head gasket was blown
Barry
Offline fred99999au
Re: IT250K Head
« Reply #3 on: June 19, 2017, 06:37:12 PM »
My bet is UNC or whitworth for the bolt.
Offline Tossa
Re: IT250K Head
« Reply #4 on: June 19, 2017, 06:46:27 PM »
thanks do you know torque settings
Offline kim80y
Re: IT250K Head
« Reply #5 on: June 19, 2017, 08:11:22 PM »
I believe from memory Suzuki ts185 are bigger on the barrel end, so can be used to replace when issues or they " mushroom " from over tightening .
Kim
Re: IT250K Head
« Reply #6 on: June 20, 2017, 08:10:21 AM »
just do them up snug using the opposite stud tightening technique until the torque wrench in your elbow goes click ;D someone must know the correct setting ::)
Offline Tossa
Re: IT250K Head
« Reply #7 on: June 20, 2017, 09:59:13 AM »
No don't know the torque settings.  That was one of my questions.  I'm thinking 16ft/lbs
Re: IT250K Head
« Reply #8 on: June 20, 2017, 11:04:55 AM »
sorry, I meant to Italianise that post of yours... ::)
Re: IT250K Head
« Reply #9 on: June 21, 2017, 09:04:10 PM »
mama mia, you hava da head problemo, need to take ita to cousin Vinny, he fixa it upa for you
doner worry, be harpy
Offline rocketfrog
Re: IT250K Head
« Reply #10 on: June 26, 2017, 08:04:27 AM »
Take your time to repair it properley as those barrels are tough to find.
Suzuki head studs are a good thing to make a repair.
The Suzuki studs are shouldered and will require either the barrel or the head to be counter bored to accomodate the shoulder.
The Suzuki Stud has a M8 thread on the head nut side (visible when stud installed) and a larger (M10 IIRC) on the barrel end.
Remove the barrel and use a drill press to make sure it is all square (cutting a hole into a thick piece of ply with a hole saw makes a nice solid base to support the barrel).
Drill the barrel to the recommended drill size for aluminium to accept the appropriate tap. Counter bore the Barrel approx 2-3mm to set the stud level with the deck or just below. You need to use a broaching tool to achieve a flat bottomed hole. If you cannot borrow one, I have sacrificed a drill by flattening the point to do the job and it will work if your careful and use a drill press with your job securely clamped into place. (success is reliant on careful set up and secure mounting of the barrel)
Tap the barrel using plenty of cutting lube and clean the threads out thoroughly before installing the new stud.
The studs you need can be found on 1980 RM's and probably lots of other models as well. Check the parts diagrams on line for other models which may be available as donors or just buy a stud from the dealer.
When you re install the head, use plenty of oil on the threads of the head nut and the face of the nut flange to head surface interface. This will help achieve a more consistent accurate torque and therefore even clamping pressure by overcoming the run on friction on when tightening. Make sure you check the nuts all run on smoothly before attempting to tighten them. Same goes with the Barrel base nuts.
Try to avoid using bodgey fasteners to make a quick fix, you will just wind up paying more when it fails and screwing over the next bloke who dismantles the donk.
Good IT250K Barrels are really tough to find! And every Enduro nut deserves to ride one of those bikes in thier life.
Re: IT250K Head
« Reply #11 on: June 26, 2017, 11:55:04 AM »
I rode one years ago thank Christ... :D nice enough bike, good brakes, rode well for a yammie
Offline Tossa
Re: IT250K Head
« Reply #12 on: June 28, 2017, 09:37:55 PM »
