Author Topic: Exhaust to silencer connector  (Read 683 times)
Offline craigclayton
« on: June 08, 2017, 11:36:01 AM »
Hi all, I am trying to connect a none standard silencer/ muffler to the original exhaust. I'm looking for a rubber connector with 25mm internal diameter and at least 40 mm long to use with hose connectors. I'm sure there are many bike manufacturers that use or used this kind of setup but without spending lots of time on Partzilla I thought some one on the forum could steer me in the right direction as to what bikes used this.
Cheers C
74 Bultaco 250, 77 RM125b
Online fred99999au
Re: Exhaust to silencer connector
« Reply #1 on: June 08, 2017, 01:05:17 PM »
Go to a supercrap auto or other automotive shop and get some silicone hose. Can buy lengths off feebay cheap too. 25mm id should be as common as mud.
Offline Momus
« Reply #2 on: June 08, 2017, 02:13:49 PM »
Ordinary silicon tube may not be up to acting as the pipe. I had a heat failure using that method and used the hose over a metal joining sleeve.
« Reply #3 on: June 08, 2017, 03:32:07 PM »
Have looked in the car shops but nothing, I'm sure some bike manufacturers used flexible connectors in the 80s and 90s????????
Offline woodsy63
« Reply #4 on: June 08, 2017, 06:32:42 PM »
MX store have them. $7.95
Bad attitudes are like flat tyres.
You can't go anywhere till you change them.
Online fred99999au
« Reply #5 on: June 08, 2017, 07:56:12 PM »
Bought a metre about 3 years ago for my IT400D after the genuine Yam rubber reinforced joint failed. Still there.
http://www.ebay.com/bhp/1-inch-silicone-hose
Offline G54B
« Reply #6 on: June 09, 2017, 08:34:44 AM »
I used a short length of radiator hose out of a wrecked VS Commodore Dad's got lying around the farm to seal the pipe/silencer joint on my IT, it's been on there for four years now and hasn't failed yet.
« Reply #7 on: June 09, 2017, 10:39:45 AM »
Thanks woodsy, will order one from mx store.
Thanks all for you suggestions
C
« Reply #8 on: June 09, 2017, 07:30:51 PM »
radiator hose has been a "go to " for yonks ;D works well...
Offline micko
« Reply #9 on: July 06, 2017, 07:07:09 PM »
MCS (motorcycle specialties) do several sizes and types, available from all good walk in bike shops
RM370A RM250A RM125A RM125S YZ125C newly acquired YZ250A
