Author Topic: 85 xl 350 /83 xr 350  (Read 1916 times)
Offline ghostdancing
Re: 85 xl 350 /83 xr 350
« Reply #15 on: May 12, 2017, 08:23:40 PM »
dont now the 350 motor.. but in the 600 RFVC motors, the only difference with the cranks XR\XL it's the balancer gear: the XL has "elastic" gear system (smoother @low revs), the XR has normal "rigid" gears coupling.. so you can mount the XR crank in the XL cases, but must match it with the XR's balancer  probably the 350s have a similar setup
Offline Scuberdiver
« Reply #16 on: May 18, 2017, 07:09:59 PM »
OK motor is in after many phone call and hrs on the computer i took both stators to a bike lec  here in adelaide this guy knows  his stuff  can run ether stator in the bike
