Author Topic: H6 MONTESA 360  (Read 1370 times)
Offline euro bikes
H6 MONTESA 360
« on: February 06, 2017, 05:45:07 PM »
Hi, After some jetting specs for a Mikuni 36 mls getting rid of the Bing.
HeavenVMX
Re: H6 MONTESA 360
« Reply #1 on: February 07, 2017, 03:16:58 PM »
I have fitted several Mikunis to Montesa bikes - Cappras only but the H6 engine is almost identical in many ways to the VB360. I have used the following system and it always seems to work well.
The more restrictive muffler on the H6 along with the restricted air box (unless you have removed the extra cover which were mostly gone at time of purchase)
Standard Mikuni 36mm
- slide standard 2.5
- standard needle - 6FJ6 - start at centre clip position you may need to go to 6DH3 if still lean in the mid range
- *** needle jet one size richer - 159Q6
- standard pilot jet 35 - suggest starting at 40
- main jet start with larger 330 but you may need to adjust down as low as 280
Re: H6 MONTESA 360
« Reply #2 on: February 07, 2017, 05:40:08 PM »
Can I have the bing?
Offline euro bikes
Re: H6 MONTESA 360
« Reply #3 on: February 07, 2017, 06:56:40 PM »
Thanks MX HEAVEN, I have most of those jets. Sorry Slackwell I'm keeping the Bing .
HeavenVMX
Re: H6 MONTESA 360
« Reply #4 on: February 07, 2017, 09:13:58 PM »
As you do ;) ;D
The bike will perform better with a BING although the Mikuni will get far (far, far) better fuel consumption.
I knew a guy that fitted a Lectron flat slide back in 1978 to his 360 H6 due to the poor fuel range. The bike performed much better with the Bing but the Lectron stayed on it so he didn't have to carry fuel and the beast still had plenty of go.
I ended up with the bike and still have the Lectron somewhere
« Last Edit: February 08, 2017, 11:46:52 AM by HeavenVMX »
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
Re: H6 MONTESA 360
« Reply #5 on: February 11, 2017, 04:46:05 PM »
Bring the Mikuni to the performance level of the Bing.
http://thunderproducts.com/shop/u-f-o-ultimate-flow-optimizer/
Offline euro bikes
Re: H6 MONTESA 360
« Reply #6 on: February 16, 2017, 06:15:27 PM »
Thanks guys.
