Author Topic: '81 damper tube Works Performance mod  (Read 1390 times)
Offline GT350
« on: January 21, 2017, 03:31:52 PM »
I spotted this mod in '81 Dirt Bike. Has anyone tried this? Results?
I have an extra damper tubes here so I'm thinking about trying it out....
Re: '81 damper tube Works Performance mod
« Reply #1 on: January 21, 2017, 04:05:03 PM »
Thanks for sharing that.
Offline Oldfart
« Reply #2 on: January 21, 2017, 06:34:42 PM »
how many extra holes ??
« Reply #3 on: January 21, 2017, 08:49:49 PM »
I rode a 350 moto villa which had the stock damper holes brazed and new ones drilled. excellent performance from aset of corte cossa's
Offline Nebo
« Reply #4 on: January 22, 2017, 12:36:07 PM »
   This a old mod . If you have the Factory Maico Information Bulletins you will find this Mod.
   Try 10 wt oil.  Use Ariete Fork SEALS. Must Have a good Pressure Gauge. NOT a Tyre Gauge.
Offline mxmaniac
« Reply #5 on: February 19, 2018, 09:35:54 PM »
Nebo, with standard 81 490gs forks, what oil and pressure is a good base setting?
Maico's, the only way to go.
Offline Nebo
« Reply #6 on: February 21, 2018, 12:59:47 PM »
   Start at 1/2 Bar or 7 psi . Do not exceed 14 psi or 1 Bar . Standard Oil amount and Level
   Is per Manual.
    Fork springs may have sagged. Make some 20 mm spacers from Alloy or High Impact Plastic .
    Or Chippys Maico has new Ones.   I think .47kg are standard. Heavy are .49kg. Will check.
      Skill level and rider Weight is a big consideration.
Offline mxmaniac
« Reply #7 on: February 22, 2018, 09:24:32 PM »
Thanks mate, its always good to hear other peoples valuable information. We have been riding dads maniocs for years and love them. Cant wait to experiment myself now with the 81 490
