Author Topic: Carb float repairs?  (Read 1229 times)
Offline Curtis
    • japspec.com.au
Carb float repairs?
« on: October 05, 2016, 06:15:21 PM »
Want to cover some potentially porous spots on some old floats. (no longer available).
Can anyone suggest what to use? Was thinking of a 2 part resin? Suggestions?
Re: Carb float repairs?
« Reply #1 on: October 05, 2016, 06:56:15 PM »
Hmm. added weight could prove to be an issue.
Offline Tomas
« Reply #2 on: October 05, 2016, 07:11:40 PM »
Brass? Plastic? Brass-solder, Plastic- if you have a hole you can use soldering iron to melt the plastic to close it. not sure what king of glue is fuel resistant long term. Superglue may work. Experiment a little  :) Added weight will be negligible unless you have a big lump of solder hanging from your float  :D You can use precision scale to check diference in weight before and after repair.
« Reply #3 on: October 05, 2016, 07:24:59 PM »
set your float level by the fuel level and reset the floats after soldering (if they are brass) to the old fuel level
« Reply #4 on: October 05, 2016, 09:31:25 PM »
soldering floats is a VERY difficult job
Offline fred99999au
« Reply #5 on: October 05, 2016, 09:48:20 PM »
Especially if they are plastic.
Offline OverTheHill
« Reply #6 on: October 06, 2016, 07:38:13 AM »
solder can get into the float through the hole you're covering too if you're unlucky, rattling around & adding weight. My [bung] 36 Bing arrived minus one float [plastic or something, not brass] never been a problem for about 40 years lol.
Offline Curtis
    • japspec.com.au
« Reply #7 on: October 06, 2016, 09:44:43 AM »
They are plastic, its pretty thin in one spot...id probably put a hole in it with a solder iron nowing my luck..ha
I might try the epoxy.
Offline D project
« Reply #8 on: October 06, 2016, 01:24:16 PM »
You can buy a two part kit at the auto stores that has a powder that you sprinkle on then a liquid that makes it bond/go off
Offline micks
« Reply #9 on: October 06, 2016, 05:36:53 PM »
thinking outside the square   could a 3d printer copy them.
« Reply #10 on: October 06, 2016, 05:46:55 PM »
That would be easier than brass, as when heated the air inside the brass tries to expand the halves or blow out the solder
great idea
Offline yamaico
« Reply #11 on: October 06, 2016, 08:05:36 PM »
great idea
Wet sponge or rag on the opposite side of the float, PCB solder 63/37 Sn Pb, which has the lowest melting temp of all solders, and it's a piece of cake - done plenty.
« Reply #12 on: October 07, 2016, 12:12:48 PM »
great idea
I'll try that next time ;)
Offline skypig
« Reply #13 on: October 07, 2016, 04:36:48 PM »
I'm not sure how it would hold up submerged in fuel but I've effected some good repairs with Araldite and Al foil. Including a Toyota fuel tank long term.
I smear a little epoxy over the hole and smooth down a small patch of foil. Squeeze/rub it flat.
Cut the next patch a little larger and repeat.
Repeat as required.
Aluminium epoxy sandwich repair.
If you can isolate the offending area, and maybe get suitable epoxy (fuel grade) it could be a solution.
« Reply #14 on: October 07, 2016, 06:40:56 PM »
JB weld is fuel proof. The KLR650 has a CV carb with holes in the slide as a restrictor. i filled mine with JB weld and it now goes like a 650 should.
