Author Topic: '74 shock length  (Read 1409 times)
Offline ralph311
'74 shock length
« on: August 23, 2016, 10:21:03 AM »
Can anyone tell me the stock eye to eye shock length on a 1974 400 maico? The one with the shocks moved forward.
Is it best to stick with that length with replacement shocks?
Offline sleepy
Re: '74 shock length
« Reply #1 on: August 23, 2016, 10:33:43 AM »
Stock shocks were 13.5" Koni's with 100lb/inch springs.  To much longer than that upsets the steering angle. Also if you are going to race it you need to travel limit the shock to keep the 4" wheel travel.
Offline ralph311
« Reply #2 on: August 23, 2016, 03:07:30 PM »
Thanks sleepy. I've got a set of 340mm shocks, sounds like a perfect fit.
Offline Nebo
« Reply #3 on: August 24, 2016, 06:30:00 PM »
   HI.  340mm is spot on . What Shocks are you using .   Spring Rate and ride Height are Very important.
    All so get some new GP Fork Springs from Chippys .            As the old Dual Rate ones would have
     Sagged Long ago.
Offline ralph311
« Reply #4 on: August 25, 2016, 09:06:29 AM »
Hey Nebo.... got a set of ohlins but I think the springs will be too soft. I forget the metric measurement but about 80lbs in the old money iirc.
I should probably start a new thread, but being a lazy devil..... does anyone have any advice re rebuilding corte cosso shocks on an '81 490? I've read posts about possibly rebuilding them with ohlins parts but nothing definitive. Looking for an 'affordable' option. Cheers.
« Reply #5 on: August 25, 2016, 11:19:37 AM »
pm big K, he did a set for a mate on a moto villa
Offline KTMaico
  • "Love or Lust it's always a Maico"
    • Maico Lovers & Fans
« Reply #6 on: September 07, 2016, 07:48:07 PM »
My solution would be go straight to Ohlins shocks. This is what is on my Maico 490
Kevin
« Last Edit: September 07, 2016, 07:49:46 PM by KTMaico »
1981 Maico 490 (Special Build)
1979 Husqvarna CR250
1975 Suzuki RH250
Offline ralph311
« Reply #7 on: September 08, 2016, 02:16:09 PM »
Nice Kevin, send them over!  :)
