Author Topic: Methanol.  (Read 3312 times)
Offline Natroy
Methanol.
« on: August 20, 2016, 08:40:52 pm »
I was told that you can use methanol in modern dirt track, but not motocross.
I thought you weren't allowed to use it in DT or MX after about 1978.
Will someone set me straight on this?
Thanks.
Offline Butcher
Re: Methanol.
« Reply #1 on: August 20, 2016, 10:27:38 pm »
methanol is widely used in modern dirt track
Offline GD66
Re: Methanol.
« Reply #2 on: August 20, 2016, 11:23:22 pm »
Dirt Track MOMS Rule 17.14.5.2  :  In addition, for Senior and Classic competition, commercially manufactured pure Methanol with no additives other than lubrication oil may be used.
Also see 13.11.5.1. for classic mx and dirt track  :
 Fuel for all machines must :
(a) Be pure methanol, or,
(b) Be unleaded fuel that is no more than 100 RON etc etc...
« Last Edit: August 20, 2016, 11:52:02 pm by GD66 »
Offline Natroy
Re: Methanol.
« Reply #3 on: August 21, 2016, 10:15:13 am »
Thank you.
Re: Methanol.
« Reply #4 on: August 21, 2016, 06:25:06 pm »
methanol is finicky to set-up unless you have experience.
unless you know about it be prepared to lunch a few engines till you get it right, this advice was given to me by a renowned tuner in Geelong many years ago when i approached him to do it to my CR250 for Dirt track. i backed away.
Offline GD66
Re: Methanol.
« Reply #5 on: August 21, 2016, 08:09:57 pm »
The main thing is, do NOT go lean. Metho will cope with being way too rich and you can work your way down, but never go lean !  8)
Also, if you are getting into dirt track or vintage dirt track, or indeed any race discipline, always a good idea before you cut, weld, assemble or outlay on anything to have a quiet read through the GCRs/MoMS/Rulebook. Far too many folk have ripped into it on an impulse only to depart cursing when things don't suit their ideal vision. Do your homework and it will be a much smoother intro  :)
www.ma.org.au>competition>rules>general competition rules  ;)
« Last Edit: August 21, 2016, 09:15:26 pm by GD66 »
Offline Bamford#69
Re: Methanol.
« Reply #6 on: August 22, 2016, 08:35:47 am »
"Also, if you are getting into dirt track or vintage dirt track, or Classic Motocross, always a good idea before you cut, weld, assemble or outlay on anything to have a quiet read through the GCRs/MoMS/Rulebook. Far too many folk have ripped into it on an impulse only to depart cursing when things don't suit their ideal vision. Do your homework and it will be a much smoother intro ."
 Wise advice , and needs repeating Monthly
Offline oldyzman
  • 250 two stroke!
Re: Methanol.
« Reply #7 on: August 22, 2016, 10:11:55 pm »
Only ever had one bike run on meth (TM250), i was so surprised how cool it ran and also the nice power curve...
Bit painful washing it through with unleaded after use.
Good stuff
