Author Topic: AW 400 Mik jetting spec  (Read 982 times)
Offline Jumbo J
« on: August 12, 2016, 08:27:04 PM »
guys what jetting is good for 38mm mikuni on the AW400
main, pilot, needle, needle jet, air screw,  slide cutaway, - anything i missed?
Offline g465b
Re: AW 400 Mik jetting spec
« Reply #1 on: August 13, 2016, 12:30:42 PM »
hi,    slide  2.5     needle  6DH3    nj    Q-0 #166 series     main   330     pilot 55    clip  mid/as required       approx   120 m above sea level
        air screw  1 1/2  to 2                    from back in the day when we had real super leaded fuel.         cheers G
Offline Jumbo J
« Reply #2 on: August 13, 2016, 01:11:05 PM »
Thanks G - very helpful cheers. gearing 14T fr - Rear  ?? (currently it has a 57T) - haven't run it yet tho, most our tracks in NSW don't have long straights
Offline g465b
« Reply #3 on: August 13, 2016, 06:22:29 PM »
hi j j,  standard gearing was 13/56    g.
Offline Nebo
« Reply #4 on: August 14, 2016, 06:04:08 PM »
        Re Mikuni Jetting. g465b  has given a  good starting point. But some Mikunis have a small Air Correction Jet in the small hole in the Carb inlet.
        If this hole has a thread in it the jet should be a 0.5.  This Jet effects Starting and 1/4 Throttle.   If there is no thread do not worry about it.
Be very aware that it may have bad Detonation and Pinging in the mid to 3/4 throttle  range.                     With todays Fuel you may have to run a ritcher Needle and or Needle Jet.
  Do some testing before running the engine at race pace.   Or Engine damage will result.              Even Maico 1.01 states this when running a BING carburetor.
