Clubroom
General Discussion
1st Linkage
Topic: 1st Linkage (Read 3917 times)
Digga
A-Grade
1st Linkage
August 06, 2016, 04:58:55 PM »
Which manufacturer was first with the linkage system & on what year/model???
smed
Re: 1st Linkage
August 06, 2016, 05:51:58 PM »
1980 Kawasaki KX125/250/420
Lozza
Re: 1st Linkage
August 06, 2016, 07:59:59 PM »
KX was a rocker arm as with Suzuki's Full Floater, first true rising rate linkage rear suspension was on the 82 Cobas MR-1. The works RM/KX 125's used in the All Japan Championships had rocker arm rear ends in 1980. CR 125 had the Pro-Link in 81
smed
Re: 1st Linkage
August 06, 2016, 08:44:30 PM »
So first Uni-Trak & full floater are eligible for EVO then if they are non linkage
Nathan S
Superstar
HEAVEN #818
Re: 1st Linkage
August 06, 2016, 09:15:41 PM »
Anything that doesn't directly connect one end of the shock to the swing arm, and the other end of the shock to the frame, surely has to be considered a linkage?
BSA-B5
C-Grade
Re: 1st Linkage
August 06, 2016, 09:26:31 PM »
vincent motorcycle would have been the first
Nathan S
Superstar
HEAVEN #818
Re: 1st Linkage
August 06, 2016, 09:33:47 PM »
Bolger.
LWC82PE
Superstar
Re: 1st Linkage
Reply #7 on:
August 06, 2016, 09:34:26 PM »
Vincent was just a mono, well they had two shocks under seat really. No linkage.
Last Edit: August 06, 2016, 09:37:20 PM by LWC82PE
Lozza
Re: 1st Linkage
Reply #8 on:
August 06, 2016, 11:12:26 PM »
Vincent is a cantilever not a linkage.
Mick D
Re: 1st Linkage
Reply #9 on:
August 07, 2016, 12:14:59 AM »
This is a picture of Brad Lackey racing a Kawasaki 443 at Sittendorf Austria in 1979
Definitely not a twin shock.
"light weight, and it works great"
Digga
A-Grade
Re: 1st Linkage
Reply #10 on:
August 07, 2016, 08:50:39 AM »
Perhaps I should have said "
which production MX bike
Clubroom
General Discussion
1st Linkage
