Author Topic: XT500, de rake? Better turning?  (Read 2558 times)
Offline Curtis
    • japspec.com.au
« on: May 30, 2016, 09:13:51 PM »
Iv decided to play around with the old girl again. Iv got a standard set up 76 XT500, I do a bit of everything with it.
Id really like to sharpen up the steering for dirt track, grass track mx..etc.
Whats my best options, de rake frame? 19" Front wheel? Drop the forks? Different triple clamps?
Offline mick25
  • Hunter valley NSW
Re: XT500, de rake? Better turning?
« Reply #1 on: May 30, 2016, 09:56:40 PM »
I deraked a frame years back around 27deg what's a modern bike rake ,
But it changed the look of it to much because the rest of the bike was standard just my taste.
The tt500 I race now I just left it near standard and pushed the forks up through the triples to make it turn a bit better .
All the usa flat track bikes run 19 inch fronts 26/27 deg rake for the right corner speed .
You can try diffrent off sett triples but if it's a early model Tt,xt500 76 77 models the triples will hit the tank on full lock , it's allways the way you fix one prob and make another.
« Last Edit: May 30, 2016, 09:58:14 PM by mick25 »
« Reply #2 on: May 30, 2016, 10:51:18 PM »
also get a yamaha radian swing arm from the states fits in just change shock mounts
jim
« Reply #3 on: May 30, 2016, 11:45:04 PM »
ask brent j on here about derakeing, id send you the pm's he sent me on it but ive got no idea how to resend as i wasnt born with a keyboard and mouse in my hands like the kids of today ;) ;D
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #4 on: May 31, 2016, 10:50:03 AM »
Jacking up the rear of the bike with longer eye to eye shocks could be a way of trying the decreased rake before you cut and shut the frame.
Offline brent j
« Reply #5 on: May 31, 2016, 10:58:14 AM »
I wouldn’t worry too much about changing the rake. Trail is far more important and has a greater effect on the bike.
Changing the rake does change the trail and most of the effect you feel through changes is from the change in trail.
Tony Foale proved this pretty well. In his book “Motorcycle handling and chassis design” he gives an example of changing the rake on a BMW from 30 degrees to 15 degrees to 0 degrees but in all cases the trail was kept the same by reversing the triple clamps and/or fork offset (by reversing the lower fork legs)
As the rake became steeper the bike had less tendency to follow ruts or cambers but the suspension tended to bind up during braking.
The overall balance of the bike is more important than any one thing. Personally I would get the suspension fixed first and see how it goes then. To change the rake with the std crap Yamaha suspension means you will be chasing other problems all the time
Offline Curtis
    • japspec.com.au
« Reply #6 on: March 14, 2019, 01:19:07 PM »
Back on the topic 3 years later..haha. Do later TT500 have different offset triples to the early ones??
Offline mick25
  • Hunter valley NSW
« Reply #7 on: March 14, 2019, 01:23:20 PM »
Yes the 79,80,81 TT500 triples have less off set than the early TT500 models
Offline Curtis
    • japspec.com.au
« Reply #8 on: March 14, 2019, 03:11:16 PM »
That would help with sharpening up the turning wouldnt it?
  • ^^^ Jan 1984
« Reply #9 on: March 14, 2019, 06:40:28 PM »
lt will put more rider effort into the steering process, gives the bike more trail, hence more stability at speed. Every bike l own l have reduced triple-clamp offset to get more trail.
« Reply #10 on: March 14, 2019, 11:10:41 PM »
Don't forget that the later XT/TT models that have less offset in the triples is because they are leading axle forks so it is quite a large change
Offline Curtis
    • japspec.com.au
« Reply #11 on: March 15, 2019, 10:06:44 AM »
Well I dont more effort I want to make it turn easier..haha
Offline Curtis
    • japspec.com.au
« Reply #12 on: March 15, 2019, 10:07:42 AM »
Geoff have you ever de raked a XT/TT500?
Offline mick25
  • Hunter valley NSW
« Reply #13 on: March 15, 2019, 05:24:54 PM »
I de raked a TT500 frame years ago 27deg it turned better but it lost it original look and value.
The Flat track TT500 bikes in the USA are all de raked 25-26deg but this isn’t mx riding .
« Reply #14 on: March 15, 2019, 09:11:41 PM »
if you derake it youll need to lengthen or replace the swingarm for something longer.a klx swinger that's 1.5 inches longer goes in with not to much work and the distance from the pivit to shocks mounts is the same as the std xt swinger but youll need heavier springs/dampening
