Clubroom
Tech Talk
repacking new sealed bearings
All
Topic: repacking new sealed bearings (Read 6901 times)
Paulos
B-Grade
February 10, 2016, 11:13:07 am »
I've always pried the cover off new sealed bearings and packed with grease as they seem to come with a measly amount of grease when you buy them.
A mate was told by the guy at the bearing shop not to do this though, as too much grease will cause the bearing to overheat and the small amount of grease in there is all you need.
I'm not too keen on this idea though. Any thoughts?
Rossvickicampbell
Re: repacking new sealed bearings
February 10, 2016, 11:31:01 am »
too much grease overpacked will cause overheating - however define too much grease?
fred99999au
A-Grade
February 10, 2016, 02:33:03 pm »
The amount of grease in a bearing that causes overheating?
rocketfrog
February 10, 2016, 03:14:12 pm »
If you repack the bearing you can be assured of the the suitability of the grease for your particular application. Ask your bearing supplier if the factory grease is suited for your purpose at least. I suspect that the bearings are initially packed with a preservative type grease and I prefer to use quality wheel bearing grease ( if I am using the bearing for wheels) so I know it will be up to the task.
zorroz
A-Grade
Reply #4 on:
February 10, 2016, 03:42:28 pm »
I've always packed one side of a new bearing with good water proof grease and they have lasted 5 years on an enduro bike. But on wheel bearing that were never packed they failed with in a few years. Do it
pecrazy
B-Grade
Reply #5 on:
February 10, 2016, 04:55:14 pm »
I always pop on seal and add some grease or a bit of moly lube or other slippery stuff.
EdgyAl
Novice
Reply #6 on:
February 10, 2016, 05:07:13 pm »
What a crock of poo,
He should sell vacuum's.
Grease those suckers up.
Moto
A-Grade
Reply #7 on:
February 10, 2016, 05:20:44 pm »
I was taught when doing this on electric motor bearings to pack them 2/3rds full to stop overheating.On my bike wheel bearings I wash out the original Vaseline they come with and repack with Belray waterproof grease and as said by others they last for years.
Last Edit: February 10, 2016, 08:57:46 pm by Moto
yamaico
Reply #8 on:
February 10, 2016, 07:26:12 pm »
If you are going to pack them always do it with the palm of your hand:
https://www.youtube.com/watch?v=P_tSJq9zc-M
I know it says wheel bearings but use the same procedure on roller bearings. It's the easiest way to get the grease where it's supposed to be, just a bit messy..
fred99999au
A-Grade
Reply #9 on:
February 10, 2016, 09:46:22 pm »
Thats funny. That is how I was taught many moons ago.
matcho mick
Reply #10 on:
February 10, 2016, 10:25:06 pm »
yep,std procedure,tapered bearings sharp edges cleaned your palm up pretty good too,
FourstrokeForever
AKA Mark H #35 VCM
Reply #11 on:
February 11, 2016, 08:26:19 am »
Yep, wash the vasoline out and repack with good quality wheel bearing grease. They will last for years, even longer if you do it every year or so.
dont
B-Grade
Reply #12 on:
February 11, 2016, 10:26:22 am »
I have one grease gun dedicated to do bearings, it has a large bore hypodermic needle as the outlet and I fill the centres between the balls, rods, and the opened side. With wheels I put the side I've opened inward incase the seal was damaged.
Tony.Brown
B-Grade
Reply #13 on:
February 12, 2016, 11:39:52 am »
Now call me a cynic, but why would a person who sells bearings for a living tell you not to re-grease your bearings? I wonder?
Tim754
Northern Country Victoria
Reply #14 on:
February 12, 2016, 12:27:28 pm »
I’m still having a shit load of trouble making ceramic ones on me pottery wheel...........
All
Clubroom
Tech Talk
