Marque Remarks
Maico
Maico air filter size
Topic: Maico air filter size (Read 3959 times)
LWC82PE
Superstar
December 27, 2015, 06:55:38 PM »
What size (OD & length) is a Maico air filter for 64-79 in Uni or Twinair brand?
sleepy
Re: Maico air filter size
December 27, 2015, 07:26:05 PM »
You can still buy them new from UniFilter. Do you want to fit one to something else?
LWC82PE
Superstar
December 27, 2015, 07:59:33 PM »
Yeah if its the right size. I just want to know if i can use it for custom app.
sleepy
December 27, 2015, 09:56:37 PM »
The foam outside is about 140mm diameter and 120 deep. The cage is 100mm OD and 100mm deep. Measured through the plastic bag so only appromimate. Part number is NU 1201 ST.
LWC82PE
Superstar
Reply #4 on:
December 27, 2015, 10:13:29 PM »
Ok thanks. That's too big. Looking for something with foam measuring around 100 x 100 max.
sleepy
Reply #5 on:
December 27, 2015, 11:27:24 PM »
Bultaco Pursang filters are a bit smaller and Suzuki TM125 are smaller again. The Suzuki TM125 are open both ends though. Not sure I have sample out of bike to measure for you.
LWC82PE
Superstar
Reply #6 on:
December 28, 2015, 02:25:35 AM »
Thanks, i will look into those aswell.
sleepy
Reply #7 on:
December 28, 2015, 10:55:16 AM »
Uni filter will make a filter any size you like as a custom. Just give them your basic dimensions and normaly only takes them a few days. Not to sure if they deal with the public but you should be able to find a dealer near to you if they don't.
LWC82PE
Superstar
Reply #8 on:
December 28, 2015, 11:08:08 AM »
I am a dealer/in the trade so there's no issue there but if i can find something already made off the shelf it will be easier.
Jumbo J
B-Grade
Reply #9 on:
December 28, 2015, 06:08:48 PM »
NU 4008? (CR250M) i can check mine when I'm back from hols next week leith unless you have already ruled it out
LWC82PE
Superstar
Reply #10 on:
December 28, 2015, 07:36:52 PM »
Anything small is an option at this stage.
4008 is about 3.5' long x 5' diameter. Diameter is too big.
Last Edit: December 28, 2015, 07:52:30 PM by LWC82PE
vmxrider
A-Grade
Reply #11 on:
December 28, 2015, 08:28:04 PM »
Clark rubber sell open pore filter foam sheet (or at least they used too) about 10-12mm thick, just cut to size and glue with quick grip, made a few that way.
Marque Remarks
Maico
