Author Topic: 82 XL500 forks  (Read 1216 times)
82 XL500 forks
« on: June 21, 2015, 05:05:22 PM »
Got a good useable set of 37mm XL500 forks. $35
please ask if you need more details but basically they are only this cheap because they are in the way taking up space and i just want to get rid of them. Will be posted partly disassembled.
I also have some 82 XR500 triples too.
« Last Edit: June 21, 2015, 05:57:53 PM by LWC82PE »
Offline bebolly
Re: 82 XL500 forks
« Reply #1 on: December 26, 2017, 11:11:40 PM »
Hey don’t suppose you still have these?
Offline matcho mick
    • Moto Tumbi
Re: 82 XL500 forks
« Reply #2 on: December 27, 2017, 12:06:51 PM »
2015,for $35,there's supreme optism right there  ;D, :P
Re: 82 XL500 forks
« Reply #3 on: December 27, 2017, 01:34:47 PM »
YES i still have them and the triple clamps.
https://forum.ozvmx.com/index.php?topic=37417.msg362674#msg362674
« Last Edit: December 27, 2017, 01:37:02 PM by LWC82PE »
Re: 82 XL500 forks
« Reply #4 on: December 27, 2017, 02:17:21 PM »
thats perseverance
Offline bebolly
Re: 82 XL500 forks
« Reply #5 on: December 29, 2017, 10:23:34 AM »
Just sent you a pm
Re: 82 XL500 forks
« Reply #6 on: December 30, 2017, 10:28:56 AM »
Still for sale. Buyer wanted XR forks. Mine are XL as far as i know.
Re: 82 XR500 forks
« Reply #7 on: January 08, 2018, 07:25:45 PM »
I found out these are XR forks after all. Previous owner must of upgraded to them. I found out when looking at the drawings of the sliders on CMS, plus they just seemed too long/too much travel to be XL forks.
I pulled one apart to measure in MM
slider from axle hole to top - 355
exposed chrome (from top edge of slider) fully extended - 581-582
exposed chrome (from top edge of slider)  when fully bottomed - 333-334
total length of fork extended (axle to top of inner) - 936 - 937
travel in mm - 247-249
travel in inches - 9.724 - 9.803
damper rod length from under the piston/head to base is 305mm
total tip to tip length of chrome inner rube is 752mm
Fork caps have ugly external damage but i got some DG caps that fit these forks.
« Last Edit: January 08, 2018, 07:27:33 PM by LWC82PE »
Re: 82 XL500 forks
« Reply #8 on: January 09, 2018, 03:07:58 PM »
I'll take the forks and matching triples,they'll be an improvement on the skinny forks they put on my xr200a
Re: 82 XL500 forks
« Reply #9 on: January 10, 2018, 11:23:19 AM »
Forks are SOLD
I still have the triples and the DG fork caps though.
