Author Topic: RM 370 connecting rod  (Read 9762 times)
Offline micko
Re: RM 370 connecting rod
« Reply #15 on: May 13, 2015, 10:12:19 PM »
VMX service in Holland, I paid $300 for a rod 18 months ago. Suzuki still make the bearing and pin.
www.vmx-service.eu  $175 euro on his website.
Was easy to deal with.
« Last Edit: May 13, 2015, 10:14:53 PM by micko »
« Reply #16 on: May 13, 2015, 10:30:41 PM »
Try Samarin in Spain they will make 10 min order. Those rods look like they are from Samarin
Offline Nipper
« Reply #17 on: May 13, 2015, 11:02:05 PM »
Thanks fellas things are looking good for a rod kit for the rm.
Offline KTM47
« Reply #18 on: May 14, 2015, 11:35:39 AM »
I emailed Trimac previously I think he said the rods they make are for the next model.  N & T.
Jeroen from VMX Services in Holland emailed me once that he knew someone who made them.  He never got back to me.
I found a Chinese company one time that makes different rods and big ends etc.
I found one myself in the US.  I think the bearing and pin were still available too.  If your rod isn't worn you could just replace it.  Also I remember a post from a guy in South Africa who was going to get some made.
MAICOS RULE DESPITE THE FOOLS
Offline micko
« Reply #19 on: May 14, 2015, 07:32:17 PM »
It was the guy in South Africa that put me onto Jeroen @vmx services. 2 weeks later I had my rod, I got lucky as he had a genuine Suzuki one still in the packet but also had the billet ones that are on his website.  :)
Offline alexbrown64
« Reply #20 on: May 14, 2015, 09:24:07 PM »
Micko is onto it... http://www.vmx-service.eu/en/370-400-500cc/1099-rod-rm370-rm400.html  These would sell like hot cakes and not a bad price at 175 Euros as a kit.
Offline Nipper
« Reply #21 on: May 14, 2015, 10:33:38 PM »
I have contacted the guys in south Africa, and also anchack and sons to see if they have a rod for the rm.
Offline Ted
« Reply #22 on: May 15, 2015, 06:14:21 AM »
And I thought you were taking a break for a while ;D
81 YZ 465 H   77 RM 125 B
« Reply #23 on: May 15, 2015, 07:24:47 AM »
Fairly sure I used a YZ465 rod in a 370 once, no mods that I can recall. Not that a 465 rod is probably any easier to get.
Offline Nipper
« Reply #24 on: May 15, 2015, 01:24:44 PM »
Ted I've had my break..... It's overrated , gotta keep busy .
I suppose the yz 465 rods are next to the rm 370 rods in aisle 5 right by the corn flakes.
This is what I like about the old bikes having good people getting on board helping to find the almost unobtainable part . Thanks fellas
Offline sleepy
« Reply #25 on: May 15, 2015, 04:22:16 PM »
If it is the same as the 465 rod then use a Maico late 500 rod they are very close to a 465 rod , same other than the length which I believe is 137 for the Maico and 137.5 for the Yam. Just need to take .5mm of barrel base or run without a gasket. Maico rod are quite available at the moment.
« Reply #26 on: May 15, 2015, 04:33:49 PM »
Keen over here for one, if it comes off ..cheers
« Reply #27 on: May 15, 2015, 06:17:59 PM »
YZ465 rods are same as for 490's & according to boats.net are still available from Yamaha so I'd say much easier to get than rm370 rods
Offline micko
« Reply #28 on: May 15, 2015, 09:25:41 PM »
I believe there is afew mm difference in the length between the yz and rm rod.
