Author Topic: TY 250 A Exhaust Tab on Rear of Frame  (Read 1684 times)
Offline YZ250H
  • Back in QLD Baby !
« on: March 06, 2015, 02:56:06 PM »
Any chance someone could post a picture of the exhaust mounting arrangement at the rear of the frame ?
Someone has butchered mine.  Otherwise the frame is good and ready to be blasted  8)
Thanks in advance guys
Re: TY 250 A Exhaust Tab on Rear of Frame
« Reply #1 on: March 06, 2015, 04:32:34 PM »
Have a look part way down the page, they're a fairly simple bracket. Can't take a photo of mine as it is away having the swingarm extended & is a C anyway
http://www.bjracing.com/2009.09.01_arch.html
Offline YZ250H
« Reply #2 on: March 06, 2015, 04:36:24 PM »
Great thanks Tony
Appreciate your help
Offline David Lahey
« Reply #3 on: March 06, 2015, 05:04:09 PM »
The original is a woefully thin steel tab made with a dish to stiffen it. They last until the first time the muffler gets a decent hit
previous pseudonym feetupfun
Offline YZ250H
« Reply #4 on: March 09, 2015, 08:15:47 AM »
Yep, that's obviously what has happened David.
I might try and knock up something a bit more robust.  Is there a common fix ?
Offline YZ250H
« Reply #5 on: March 12, 2015, 01:12:06 PM »
Thinking about Grinding that tab off altogether and using one of these.  I measured the frame tube and there is enough room for a layer of foam door seal in between the bracket and the frame tube.  The strut to the silencer goes between the flanges and bob's your aunties husband.
http://www.jpwmarine.com.au/products/deck-hardware/canopy-fittings/canopy-clamps-s-steel-hinged.aspx
Question is will the part that goes around the frame clash with the rear guard ?
Whadyareckon ??
« Reply #6 on: March 12, 2015, 01:25:28 PM »
Your overthinking it Tony, go down to ENZED hoses and get a "P" clip that holds hydraulic hoses on trucks/earthmoving vehicles. Just get the right diameter.
Offline David Lahey
« Reply #7 on: March 12, 2015, 05:28:20 PM »
if you are using a standard shape rear guard there is a suitable gap between the inside of the frame tube and the mudguard for the hydraulic line clip that Davey Crockett suggested. I used a strip of thin stainless steel that looped over the frame tube for that purpose for many years on one TY
Offline YZ250H
« Reply #8 on: March 12, 2015, 06:39:21 PM »
Thanks fellas. I think I'm onto it now.
Tab comes off then I can blast the frame.
Thanks again for you help fellas
