Clubroom
Tech Talk
Painted plastics
Topic: Painted plastics (Read 2109 times)
CRTAD313
C-Grade
Painted plastics
December 14, 2014, 04:28:54 pm »
Tidying up a bike that has painted number backgrounds. Any tips on how to remove the paint for proper backgrounds? I'm guessing paint stripper would be too harsh on the plastic.
Re: Painted plastics
December 14, 2014, 06:59:45 pm »
I used a Bostik product called enviro-stripper on my yz plastics without any problems. Obviously a test run in a hidden spot on your plastics would be a good idea.
Broad-Arrow
C-Grade
December 14, 2014, 07:20:25 pm »
I use Dupli-Color Paint Stripper to remove plastic side-cover decals etc. Works very well and doesn't affect the plastic.
I can't claim credit for the approach, as I used the technique described at:
http://www.flashredbikes.com/decalinstallation.htm
pokey
Arse .. Elbow. Know the difference
December 14, 2014, 07:51:17 pm »
Spill some Dettol on it and see what happens
alexbrown64
Reply #4 on:
December 14, 2014, 08:42:14 pm »
You can try a small test section but in my experience, normal paint stripper from Bunnings works well and doesnt affect the plastic. The plastic on motorbikes is propylene based and you can pour petrol on your tank and guards without any problems. Here are some RM80 plastics that were painted. They had a thick coat of paint over all the mudguards and side covers. I uses normal stripper without any problems.. before and after pics below...
Alex
Ngapuhi
Novice
Reply #5 on:
December 20, 2014, 02:02:52 pm »
I use plastic paint stripper in an aerosol can. Get it from a automotive paint supplier. It's designed to remove non oem paint from plastic without deforming or damaging the plastic.
Clubroom
Tech Talk
Painted plastics
