Author Topic: CR125/250/500 84/5/6 rear brake torque arm  (Read 2583 times)
Offline smed
« on: August 01, 2014, 11:55:54 AM »
My rear wheel backing plate bearing where the torque arm fits up is knackered on my 85 CR, I could not get one from Honda & the bearing shop could not either :(
I'm guessing they are the same from 84-86,has anyone else run into this?
Any fixes?
Offline YZ250H
  • Back in QLD Baby !
Re: CR125/250/500 84/5/6 rear brake torque arm
« Reply #1 on: August 01, 2014, 12:59:29 PM »
There's a bearing on the front and just a bolt at the back on the 84 500 from memory (it's been a while).
There's a thread on here with a replacement bearing for the front (somewhere).  The standard one is an odd size and NLA - is that right  :-\
Offline smed
« Reply #2 on: August 01, 2014, 01:18:44 PM »
Thanks ,The arm has a spherical bearing on the front and a saddle mount on the brake plate end, There is a spherical bearing in the brake backing plate,
 That,s the one I need to fix,it's NLA as far as I know, the front also needs replacing,sound like they are NLA as well :(,both bearings are the same I.D. but different O.D. ;)
Offline YZ250H
« Reply #3 on: August 01, 2014, 02:07:18 PM »
OK, I'm with you now.
Here's the thread for the front one.
http://forum.ozvmx.com/index.php?topic=25509.0
Looking at a parts diagram it turns out the 1984 only has 2 collars.  That's why it wasn't ringing any bells.
Offline smed
« Reply #4 on: August 01, 2014, 02:18:53 PM »
Sweet, thanks Tony that will get the front sorted did you get them from that website or the local bearing shop?
Just need to get the rear one sorted now ;)
Offline YZ250H
« Reply #5 on: August 04, 2014, 07:15:21 AM »
I got mine from the retailer in Geebung from memory.  If you can't find an outlet give me a yell and I will see what I can find.
Offline rocketfrog
« Reply #6 on: September 19, 2014, 06:06:46 PM »
Is it 19 mm outer and 8 mm inner for the front spherical bearing, these are common.
Offline smed
« Reply #7 on: September 25, 2014, 05:03:21 PM »
I gave up on it & fixed it this way, Gotta drill some worksy looking holes in it yet though, ;), Solid round ally bar with milled flats, drilled & tapped to suit bearing shop tie rod ends & pressed a reducing bush to suit an 8mm bolt into the rear brake plate,Sorted :)
Offline smed
« Reply #8 on: September 25, 2014, 05:12:48 PM »
Good enough for HRC, Good enough for me ;)    Crap I love this RC500 8) 8) 8) 8) 8) 8) :) :) :) :) :)
Offline E74
« Reply #9 on: September 25, 2014, 06:46:58 PM »
I have these for $100
