Author Topic: Kramit RV3 Rebuild  (Read 15136 times)
Re: Kramit RV3 Rebuild
« Reply #75 on: June 24, 2015, 09:40:35 AM »
The other way around the more preload the greater gas pressure it takes to open the valve the later it opens. You will probably find the near maximum setting gives more linear power. Remember to make sure the bleed hole is clear to the exhaust duct.
