Author Topic: RM cdi units  (Read 1493 times)
Offline Tomas
RM cdi units
« on: August 22, 2013, 04:30:01 pm »
Just would like to ask for help  with cdi unit. I have a 1980 RM80 cdi unit. Can i use it on my 1979 RM125? Both units look identical apart from part numbers.
Thank you.
Tomas
Re: RM cdi units
« Reply #1 on: August 22, 2013, 04:48:36 pm »
RM 80  79 -80 -81 use the same CDI .... according to Suzuki .
Rm 125 and 100 share the same CDI  also
Offline Tomas
Re: RM cdi units
« Reply #2 on: August 22, 2013, 06:18:09 pm »
Thank you. So should i use Rm80 cdi on my RM125.Someone on this forum mentioned that RM 125 cdi works well on PE175 and also Ts185 works well on TM/RM 400. Also 1980 RM100 and RM400 shared the same cdi unit as far as i know. So is there any chance of blowing motor up or motor running too hot doing  this swap?
Offline oldyzman
  • 250 two stroke!
Re: RM cdi units
« Reply #3 on: August 22, 2013, 06:31:59 pm »
Being a 125 you are probably gunna give it a flogging, unless someone else has tried then i would not. If it was a Coil then why not. But the cdi advances the curve etc...
Brett
