Author Topic: TYPE 54 ENGINE PARTS PDF OR PAPER COPY WANTED.  (Read 1036 times)
Offline ELC hunter
« on: July 31, 2013, 03:59:03 PM »
Hi has anyone have a pdf file or paper copy of engine parts for a type 54 engine 77 250 gs. After some small parts and need numbers for them.Or a site where I might find such info.Who in Aust has any parts for these engines,or does most bits come from that al bruerner guy in the states? Need one fancy nut with  shoulder for clutch the ones that the little split pins go through.Primary drive key,or a model that matchs.I bought a gasket kit for it but the base gaskets are slightly different ie square r  ,my cases are more rounder and flowing is there a difference between years or models. what is correct part no for gasket set. Cheers ELC hunter.
Offline MauriceR
Re: TYPE 54 ENGINE PARTS PDF OR PAPER COPY WANTED.
« Reply #1 on: August 01, 2013, 03:13:58 AM »
Why not just order the parts manual from Buehner, for $15 you get the complete parts list and all part numbers for the whole bike, frame & motor. The gasket kit I bought from dirt bike parts came with both styles of base gaskets and was $32 less than Buehners (not sure if they ship to Aus though)
I know KTM Klassiker also has lots of parts but have never ordered from there.
As I am in Canada I have no idea about parts suppliers in Aus.
I am sure ozktm will be able to tell you though
you will need to translate ktm klassiker website ( i use chrome)
http://www.ktmklassiker.com/artikel/
http://www.pentonpartsusa.com/8b%20repair%20ktm.htm
http://vintagedirtbikeparts.net/PistonKitsBearingsClutchKitsRodKitsReedValves4.htm
