Author Topic: Pre-65,,,Eligible MAICO s  (Read 29082 times)
Re: Does any one know if these TRIPPES are Pre-65 legal please
« Reply #15 on: August 20, 2013, 10:30:35 PM »
This ebay sale reckons he pulled a set the same of a 66 Ducati scrambler.
http://www.ebay.com.au/itm/251306962299?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
wondering if they were around in 1964 as well? any one know please.
If I turn up at CRC pre-65 with these will anyone have a hissy fit?
Montynut
Re: Pre-65,,,Eligible MAICO s
« Reply #16 on: August 20, 2013, 10:37:33 PM »
If you turn up to the CRC with those on the mighty Maico you'll be very welcome (unless you holeshot the first race :P) we need to German presence 8).
As to their legallity at a National then we'll leave that to someone else
« Reply #17 on: August 21, 2013, 09:51:06 AM »
They appear to be early Ceriani clamps so if I was the scrutineer at the Nats I'd allow them. Email the photo to Dave Tanner via PM....I guarantee he'll pass 'em
« Reply #18 on: August 21, 2013, 10:23:44 AM »
Will do, thank you Montynut and Firko.
I have a Norton road-holder front end but the alloy sliders are damaged and flogged out. A bloke in Bendigo sells new ones, but only has one side in stock at the moment.
Anyhow up and atem, fingers out and crossed.
« Reply #19 on: October 04, 2013, 02:00:36 PM »
 This Maico Metisse looks to be based on a Petite Metisse frame and is pretty much what I'm building only mine will be a 350.
albrid-3
« Reply #20 on: October 04, 2013, 10:02:23 PM »
very nice
« Reply #21 on: January 21, 2014, 10:15:58 PM »
This is what I am talking about, Thanks to Maico Mac(newby aka Marcus)
This is his 1964 X3 framed alloy oval barreled MC250
Cool as  8)
« Last Edit: January 21, 2014, 11:21:43 PM by Mick D »
« Reply #22 on: January 21, 2014, 10:49:44 PM »
Calling Marcus.
What is the outside diameter of the forks? At the top.
Offline Maico-Mac
« Reply #23 on: January 22, 2014, 12:32:59 AM »
Calling Marcus.
The tubes are 36'er, that means exact 35,80 mm diamter. In the top clamp they have a konus!
Here are 3 of the 4 typs I know. The first one (1964-65) was also available with iron lower end (tree ??)
And the last one is for the first square barrel Modell with X4 Frame (1968)
ca. 1966-67
« Last Edit: January 22, 2014, 01:30:36 AM by Maico-Mac »
Offline Maico-Mac
« Reply #24 on: January 22, 2014, 12:48:36 AM »
The following 1962 X2 framed bike is reputed to be the very mount belonging to the late Jim mcCabe.
If that's the bike Mick it'd be a pretty trick engine, maybe even a bigun'.....326cc.
Biggun with iron barrel is limited to 277ccm = 71mm bore x 70mm hub
If you bore the 71 mm cylinder (it's diffrent to the 250ccm) to 77mm no iron is left for the liner or sleeve or ... how do you call it ?
« Reply #25 on: January 22, 2014, 10:51:50 AM »
Excellent, danke Marcus.
What is the outside diameter of the alloy fork sliders at this point?
Offline Maico-Mac
« Reply #26 on: January 23, 2014, 03:29:50 AM »
Soo, you asked for mor pictures of this beauty ?!
Here they are. The first on I shot with my phone some years ago, thats why the quality is not very good ...
Nevertheless I hope this wil help!
To get some more pics, is impossible in the Moment, because the bike hangs on a wall in a private museum  ???
« Last Edit: January 23, 2014, 06:52:55 AM by Maico-Mac »
Offline Maico-Mac
« Reply #27 on: January 23, 2014, 07:29:23 AM »
The diameter is 42mm. What are your plans, are you searching for one ??
« Reply #28 on: January 23, 2014, 10:51:30 AM »
Thanks Marcus....the Metisse photos are very handy. That WeBeHa frame is a cool find. You can clearly see that the later X3 wide frame was almost a copy of the home built frame. Are the dimensions the same? I wonder if I could modify a 1969 frame to be a "replica" of the WeBeHa? Marcus...I used to be in touch with a German guy named Ulrich that once worked at the factory but I lost contact with him. He possesses much of the export and production paperwork that he retrieved from the trash. Do you know him by chance? Thanks for the PM re: the gold tank by the way. That's cool, I await your follow up.
« Last Edit: January 23, 2014, 11:06:12 AM by firko »
« Reply #29 on: January 23, 2014, 12:24:54 PM »
No Firko, as far as using an X4 frame as a donor for an 1964 X3 frame fabrication goes;
I think the only components that could be salvaged from the X4, would be the steering head, the under-seat top mount of the rear sub-frame and maybe parts of the foot-peg mounts.
I have another 1964 X3 frame on the way if you would like to use it as template for a jig.
