Author Topic: mini shed clean out  (Read 3230 times)
Offline motomaniac
mini shed clean out
« on: January 03, 2013, 09:42:22 pm »
yz125 e frame,forks,(airbox air boot,sold), triple clamps ,shock + a few small bits and pieces.some plastics
cr250rc tank, shock, pegs,brake levers ,Sprocket 54 tooth used but some life left,barrel with new piston ported by Steve Benolkin in the US brackets etc ,new DG muffler , new DG pipe(that doesnt fit)
Yamaha early front wheel with original mudder rim, starting to crack at join.sold
IT400/425 pipe , good nick except for some damage were silencer was welded on.sold
Yamaha MXB frame and swingarm #509 sold
yz125 c tank ,stripped and ready for painting for HL500( comes with tap and cap)sold
YZ125C seat GC  for HL500sold
KTM250 mc5 motor , various spares , wheels.
Bell Moto 4 ,Rick Johnson colors , peak is damaged on corner.
Ohlins shock for 84 model CR's , rebuilt and ready to go , medium spring with light rebound setup
85/86 cr250 frame , has bash plate welded on rough but otherwise not bad , 86 CR125 swingarm, triples , some brake parts etc
More listed later
make offer(s) inquiries via PM
pick up only Moorabbin area southeast melbourne.
« Last Edit: February 04, 2013, 10:30:09 pm by motomaniac »
Offline oldyzman
  • 250 two stroke!
Re: mini shed clean out
« Reply #1 on: January 04, 2013, 03:03:16 pm »
Gday,
Can you pls tell me how many teeth on the rear sprockets for the CR250RC as i am sure it will fit my RD which has the drum backing plate on the same side as the sprocket. Also are the footpegs good as mine are a bit bent and i would prefer straight ones..
Cheers Brett
Offline crs-and-rms
  • heaven 23
« Reply #2 on: January 04, 2013, 03:57:09 pm »
intrested in the cr ohlins shock and the yz 125 seat pm sent
Offline motomaniac
« Reply #3 on: January 04, 2013, 07:15:17 pm »
Gday,
Cheers Brett
I think 52 and 54 , def 82/83 . The pegs are good ,have wideners welded on , need clean up and paint .
Offline motomaniac
« Reply #4 on: January 04, 2013, 07:37:16 pm »
a few inquiries about the KTM  motor so Im answering everyone here . eng number is 7-5416653
date stamped looks like 76 but the 6 is a bit damaged . It came with an mc5 as a spare .If anyone can ID from the engine # plz let me know.There is some repairs done above the fr sprocket , crank is tight and has been stored in oil.
Two rear wheels with sprockets one has a SUN rim the other Nordski? and is dated 82.
Offline motomaniac
« Reply #5 on: January 06, 2013, 10:51:34 am »
MXB frame and mudder front wheel are sold . thanks
« Reply #6 on: January 06, 2013, 11:51:44 am »
MXb 250 frame and mudder to guess who .
Offline motomaniac
« Reply #7 on: January 06, 2013, 01:50:57 pm »
IT425 pipe sold. Thanks
« Reply #8 on: January 06, 2013, 03:42:00 pm »
Do you have an MC5 ? If so would like to see some pics.
Offline Eddy#36
« Reply #9 on: January 06, 2013, 07:19:02 pm »
cr250rc tank, shock, pegs,brake levers ,Sprockets new and used,barrel with new piston ported by Steve Benolkin in the US brackets etc ,new DG muffler , new DG pipe(that doesnt fit)
Keen on DG pipe and muffler, PM if still available and price ;D
Offline motomaniac
« Reply #10 on: January 07, 2013, 07:28:31 am »
yer I will get around to it oneday.
Offline motomaniac
« Reply #11 on: January 23, 2013, 06:44:02 pm »
YZ125 C tank sold
YZ125C seat sold thanks
