Author Topic: XR200 kickstart slippage  (Read 5479 times)
Offline DIRTPILOT72
« on: April 16, 2012, 10:12:52 pm »
I heard most XR200 2 valvers eventuly slip on the kickstart. I also heard its a split the cases job to fix? How much approx would it cost to have a shop to do this?
« Last Edit: April 16, 2012, 10:33:56 pm by DIRTPILOT72 »
Honda XR200 x2
Honda XR250
Yamaha Yamahopper QT50
albrid-3
Re: XR200 kickstart slippage
« Reply #1 on: April 16, 2012, 10:32:11 pm »
I would also be interested to know too.
Offline brent j
« Reply #2 on: April 16, 2012, 10:37:51 pm »
I don't know about slippage problems but the kick start mechanism is inside the centre cases, like early Suzukis.
I know only too well, I have both..................
« Reply #3 on: April 16, 2012, 11:22:01 pm »
hrs to do the kick start gears and while its apart replace leaking seals/cam chain/rings and lap the valves 5hrs motor out of frame or 7 hrs in frame @$90 per hr plus parts itd be better to sell it as parts as there not worth much
80hybridRM400
« Reply #4 on: April 17, 2012, 12:58:22 pm »
take the kick starter off, where its split, grind it out so you can tighten it more and it should not slip anymore
Offline DIRTPILOT72
« Reply #5 on: April 17, 2012, 01:08:11 pm »
Thanks for the info.
Honda XR200 x2
Honda XR250
80hybridRM400
« Reply #6 on: April 18, 2012, 10:03:04 am »
no prob bob ;)
Offline gorby
« Reply #7 on: April 18, 2012, 09:15:31 pm »
it is an internal slip that happens,you will need the two ratchet gears and sometimes the gear on the shaft behind the clutch basket.
this problem is usually caused by not having the auto decompression cable hooked up or adjusted properly.We all know that they can be started without the cable but the trade off is the wear on the gears
