Marque Remarks
Yamaha
liner fitting , advise pls
Topic: liner fitting , advise pls (Read 2188 times)
lms6201
March 20, 2008, 06:55:08 AM »
what is the process for fitting a new sleive ? is the barrell heated or can the liner be pressed out / in cold , all recomendations pls
brent j
Darwin, NT. Suzuki tragic, RL250M TS90MX PE250B
Re: liner fitting , advise pls
March 20, 2008, 05:20:20 PM »
The liners I've changed in the past were done with heat. To remove a liner I put it in the oven upside down with the barrel supported but not the liner. Raise the temperature till the liner drops. Last time I got to about 140 C
To refit them. Heat the barrell and put the liner in the freezer. I leave them for a couple of hours at least. I heat the barrel to a bit lower than what it took to get the liner out. The frozen liner makes up for the lower temp and still give a bit to play with. Have the barrel upright and drop (lower) the liner in. put some weight on the liner to hold it as the barrel cools
Temperatures will increase dramatically if you get caught doing this with out permission!!!!!!!!!!!!!!!
Brent
Lozza
March 20, 2008, 05:35:30 PM »
Along with Brent's good advice(especially keeping the weight on, otherwise it will pop up when cooled), you will have to learn to see which liners actually press out as many oldtime barrels have cast in liners.Can you post a pic?
lms6201
March 20, 2008, 09:49:48 PM »
no pic,s but it,s a late 490 , am thinking of the wiesco liner , cheap. also do they have to be bored ? or are they sized to std out of the factory , thanks muchly for the advise already ,
David Lahey
Gladstone, Queensland Australia
Reply #4 on:
March 21, 2008, 09:44:45 PM »
Steve
Yamaha and other Jap brands cast the aluminium bit around the steel/cast iron bit so the steel/cast iron bit has to be machined away. It's Bultacos and OSSAs that you can take the sleeve out with heat.
Fitting the new sleeve to the 490 is as described above.
David
previous pseudonym feetupfun
Lozza
Reply #5 on:
March 21, 2008, 10:08:38 PM »
I have done 70% of a 490 resleeve, unfortunately you will need access to a good size lathe, a pipe centre and a face plate.There is a fair bit of machining involved and a fair bit of work with the porting tool when the liner is fitted.Remember when time comes to fit the liner there won't be much time to work with as the liner starts to heat up rapidly.Then there is the rebore after all that to as the ID of the new liner is about 1mm under size :'(
Suzuki's and Kawasaki's press out fine.
lms6201
Reply #6 on:
March 22, 2008, 09:11:11 PM »
thanks people , seeing as my lathe is a baby , i,ll get it done , is serco still around ?
Oldrodder
Reply #7 on:
March 22, 2008, 09:20:37 PM »
If your in the Hunter Valley area we have a bloke at West Wallsend that does them for most of the bikes around here.
Lozza
Reply #8 on:
March 22, 2008, 09:48:36 PM »
Sending the barrel to Dave Hall would be a good idea as Dave does great work for very competitve prices.
Marque Remarks
Yamaha
