Author Topic: Call me Crazy but this is my Summer Project  (Read 19714 times)
Offline vmxken
Re: Call me Crazy but this is my Summer Project
« Reply #60 on: August 07, 2012, 10:17:37 AM »
'Kenneth's Caboose' - it has the steam train connection and it is almost the correct name for the use of the trailer.
Offline Kenneth S (222)
  • Administrator
  • Sydney, Australia
    • 24 Hour T-shirts
« Reply #61 on: August 07, 2012, 11:52:16 AM »
 ;D
Kenneth S
Go For It
Race Bike History
Simo63
« Reply #62 on: August 07, 2012, 11:56:34 AM »
What about "The Sauna" .. still keeping with the steam theme?
The Swan Express (you know Orient Express .. Swan express)
The Swanneth
The Swan Lander (Lunar Lander)
The Swanken
The Kenswan
« Last Edit: August 07, 2012, 12:10:59 PM by Simo63 »
Offline Ando
« Reply #64 on: August 12, 2012, 08:31:49 AM »
Ha Ha Ha!!! More like the "BAT" Trailer  ;D ;D ;D
Offline matcho mick
    • Moto Tumbi
« Reply #65 on: August 12, 2012, 08:42:57 PM »
i like swanlander,it's aluminum,just like the moonlander & sunlander,you banana benders should identify with that  ;D, :P
  • Administrator
  • Sydney, Australia
    • 24 Hour T-shirts
« Reply #66 on: September 24, 2012, 01:46:40 PM »
Well, we took the new beast for a test run last weekend and all went well. There is still plenty to do but we are on the road and it is now usable.
Kenneth S
Go For It
Race Bike History
Offline EML
« Reply #67 on: September 24, 2012, 04:22:11 PM »
Swanlander sounds good to me. Almost a production model name there. :D
Offline gorby
« Reply #68 on: September 25, 2012, 07:59:42 PM »
MegaTardis..... :)
Offline BAHNZY
« Reply #69 on: September 25, 2012, 09:18:40 PM »
Kenneth.... ;D....did you do your  homework on the download (loaded) like we discussed early on in the thread? The D40 RX will handle 3000 kg (I'm guessing its a 4x4) and 300 kg on the ball as long as you drop 200 kg from your GVM figure. I have a D40 ST-X 550 and a trailer not that different to yours in size, but significantly different in the placement of the trailer axles and I struggle to not exceed the vehicles tyre rating with gear in the tub. Not sure what the NSW RTA is like, but down here in VIC they check these sort of figures via mobile weigh bridges and there is zero tolerance at inspection.
In the end what was your final tare?.......and gross & download on the trailer when loaded?
Rod (BAHNZY) Bahn
Offline Snowy 76
« Reply #70 on: September 25, 2012, 09:59:16 PM »
I`ll have a Pie and Chips thanks Mate! ::) ::) :D Looks like a good thing Kenneth.
Couple of CR`s
  • Administrator
  • Sydney, Australia
    • 24 Hour T-shirts
« Reply #71 on: September 26, 2012, 05:14:54 AM »
Hi Bahnzy,
Yes mate I did and your comments helped thanks. My RX is rated 2000Kg even though the tow bar is rated 3000Kg. Must have something to do with it being a 2 wheel drive, not 4. This made me very weight conscious with my design. The original frame I started with was 1280Kg. I kept the build all aluminium to keep the weight down and because I like aluminium and the final shell as you see it now ended up at 1560Kg. I have registered it with a GVM of 1999Kg so I have 439Kg to play with for the fit out and load. I am going to keep the fit out modular and build all the frame work out of aluminium so I can tailor the load to keep it under 2000Kg. When I had it weighed I checked the weight on the bar and it came in right in the 10-15% range at 180Kg. On it's first trip last weekend with 2 bikes in the back and all the gear in the front it towed very nicely and on the Freeway cruised at 100Km without much effort. Slow up the hills though. The 4 x 12" electric brakes are amazing, way over engineered for the trailer as it is now so I can stop it on a dime. Interestingly, the original trailer had a rating of 6000Kg to carry 5 horses and the axles are rated at 3000Kg each so I have plenty of scope in the future if I change tow vehicle.
Kenneth S
Go For It
Race Bike History
Offline Ando
« Reply #72 on: September 26, 2012, 07:47:17 AM »
Now that is "gold"  :D :D :D :D :D
Offline Ando
« Reply #73 on: September 26, 2012, 07:58:26 AM »
Well here is a challenge for ya's what does a horse weigh???
« Last Edit: September 26, 2012, 06:59:01 PM by Ando »
Offline BAHNZY
« Reply #74 on: September 26, 2012, 04:01:54 PM »
Correct 2WD is rated at 2000 kg's and the 4x4 at 3000 kg's, the point to remember is that the download also varies between 4x2 & 4x4.
For a 2WD dual cab your calculation is as follows.
Download @ 70kg  - No reduction of GVM
Download @ 100kg - Reduced loaded vehicle mass below GVM by 40kg
Download @ 150kg - Reduced loaded vehicle mass below GVM by 110kg
Download @ 200kg - Reduced loaded vehicle mass below GVM by 180kg
With this in mind, you must reduce your payload from 960kg to 800kg (calculated by GVM @ 2860kg minus AT/Tare @ 1899kg = 960kg)
So if you have a towbar and other accessories that weigh (eg) 50 kg then you are down to 750 kg. If the passengers are the Aussie family of mum/dad & 2.5 kids then you will have to take away another 240 kg's leaving you with a carrying capacity of no greater than 510 kg's.
The key point to remenber is that you only have 20kg's to move on the download and that can dissapear in a heartbeat with an extra few goodies snuck in through the front door. ;)
Most trailer manafactures work on 550 kg The reality is that its not unusal for a larger breed to come in at 800+ kg's
Rod (BAHNZY) Bahn
