Author Topic: 1976 RM 370 forks  (Read 2755 times)
Offline Nipper
1976 RM 370 forks
« on: October 15, 2011, 09:31:40 am »
Hi I am looking for a set of forks for a RM 370. I believe this type of fork also suited the 250 of the same era.
Offline BAHNZY
Re: 1976 RM 370 forks
« Reply #1 on: October 15, 2011, 11:04:33 am »
Which model 370?
A or B as they are rather different.
Rod (BAHNZY) Bahn
Offline Nipper
« Reply #2 on: October 15, 2011, 12:05:29 pm »
this is for the A model
Offline Husabergpete
« Reply #3 on: October 25, 2011, 09:16:18 pm »
Nipper I have a good set of lower alloy fork legs. Need to check if they are A or B. A ones have a thread in the leg itself and B run a separate nut from memory. The top end of the forks have a necking or taper where the top cap fits in. Ta Pete
Offline Nipper
« Reply #4 on: October 26, 2011, 07:40:38 pm »
 Thanks Pete, The forks that I have for this bike have spent a fair time out in the elements and have been damaged by having water in them,The lower alloy fork legs that I have arent in too bad a condition but its the staunchions and the damper rods that I am after to make them work again...would you have any of those parts ? regards Nipper.
« Reply #5 on: October 28, 2011, 07:56:02 pm »
Nipper, sorry not  a real lot. all gone. I just had forks re-chromed and ground in Sydney at a reasonable price. Not sure where you are. let me know if you want to re do the old ones which are hard to get Pete
« Reply #6 on: October 29, 2011, 09:08:18 am »
I have 3 sets A/B including clamps, none perfect but all are restorable. There's probably only one set you could use with a service.
Offline Nipper
« Reply #7 on: October 29, 2011, 04:07:18 pm »
Chers Pete  i am in Adelaide , I have used hard chrome services to do the rechroming before. They were reasonably priced and provided a good service.
Offline Nipper
« Reply #8 on: October 29, 2011, 04:08:19 pm »
Hey BigK I will pm you.
« Reply #9 on: November 06, 2011, 02:04:17 pm »
Nipper check these ones out - RM 370 forks, tripple clamps, axle, spacers and bolts - the lot
330615357661   This is the item number or Ebay - Located in Texas with a guy I have been dealing with for some time. Very good shipping too.
themotorecycler  is the business name and his name is Rich.
He has some other RM 370 bits too.
Ta pete
Offline Nipper
« Reply #10 on: November 07, 2011, 09:50:16 pm »
Hey thanks Pete for keeping an eye out .I will have a look now.
