Author Topic: 1974 Yamaha MX250 Timing  (Read 6620 times)
Offline mposs
« on: March 18, 2011, 08:41:37 pm »
Hi,
     Can someone please point me in the right direction for setting the timing on a MX250 with standard ignition components?
Cheers Mark
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: 1974 Yamaha MX250 Timing
« Reply #1 on: March 18, 2011, 09:01:46 pm »
Jam a dial indicator down the spark plug hole & rotate crank until the piston crown is 2.4mm Before Top Dead Centre (BTDC) then align the two timing marks shown in your pic. That should be pretty right ;)
"flat bickie"
Offline mposs
« Reply #2 on: March 18, 2011, 09:19:24 pm »
Thanks Vandy. I knew someone on here would know. Cheers Mark
« Reply #3 on: March 23, 2011, 03:42:22 pm »
YEp how easy is that !  if your real lasy and just wanna see if it runs shove somthing in the head that point out, find the point it hits highest spot mark it and cam back a poof tenth. ( couple a mm in tech terms)
and if it dont run you got other issues   ;D
Offline mposs
« Reply #4 on: March 27, 2011, 09:07:57 pm »
She's a runner. Thanks Gentlemen.
Offline vandy010
« Reply #5 on: March 27, 2011, 10:39:36 pm »
supercool 8)
they're a really neat work truck the MX250,
mine's stock with a DT piston and i love it.
have fun :)
"flat bickie"
