Author Topic: yz125A ignition/ stator - YZC125 seat base or complete  (Read 3906 times)
« on: February 07, 2011, 08:05:15 PM »
as above
Re: yz125A ignition/ stator - YZC125 seat base or complete
« Reply #1 on: February 07, 2011, 08:35:23 PM »
Replica plain plastic base - no mounts $ 66.00
Replica plastic base with mounts fitted $ 110.00 (as pictured)
« Reply #2 on: February 07, 2011, 09:58:43 PM »
as in plastic plastic or fiber glass ?  i have seat base with shitty foam but the last 10cm has been cut from the front.  it has the rear mounts, and i can probbly fab the front one.  are the seats normally stapled or metal teeth hooked on ?
« Reply #3 on: February 07, 2011, 10:09:18 PM »
These bases are made from plastic plastic.
Original bases are made from plastic plastic also.
Not sure but I think the covers are stapled on.
Offline holeshot buddy
  • sunshine coast qld
« Reply #4 on: February 07, 2011, 10:15:35 PM »
thats cheap buy it freaky :o
follow me to first turn
« Reply #5 on: February 07, 2011, 10:25:15 PM »
hey geoff, while your on a roll.  can you post up the 125A chamber/pipe and filter-airbox you make ?
« Reply #6 on: February 07, 2011, 11:00:07 PM »
« Reply #7 on: February 07, 2011, 11:07:30 PM »
Stop being a tightarse Kerry....buy the lot.....for christs sake...it ill keep him off the forum for a couple a days ;D
TM BILL
« Reply #8 on: February 08, 2011, 07:01:23 AM »
Freaky that pipe aiibox combo will be the best money you can ever spend on a YZ 125A  ;)
Or is that a 250 front end and decent shocks  ???
« Reply #9 on: February 08, 2011, 08:16:06 PM »
id like to but i have had some real bum deals lately, that set me back, so im im short of that sort of cash, so im living in hope. pipe might be a goer in the short term though, depending on price.
« Reply #10 on: February 09, 2011, 05:33:08 PM »
Pipe is $418.00
Muffler is $209.00
Pipe and muffler is $600.00
Airbox is $286.00 plus filter and cage
Postage $22.00
I have had some real bum deals lately too, that have set me back, so I'm short of cash too, so im living in hope the pipe might be a goer in the short term
« Reply #11 on: February 10, 2011, 12:37:43 AM »
Geoff you jigged for that pipe or you need a frame ?
whats the dia at the muffler end ?  i have a few can around here and some old HPF stuff that might fit....
« Last Edit: February 10, 2011, 01:43:37 PM by Freakshow »
« Reply #12 on: February 10, 2011, 07:47:03 AM »
Freaky, you just bolt it on and go.
« Reply #13 on: February 10, 2011, 10:27:13 AM »
im prity keen at that money
All pipes and mufflers on my price list are jigged for.
The stinger tube is 1" - 25.4mm OD
Any muffler with a similar core size will do, muffler body should be around 200mm long
« Reply #14 on: February 10, 2011, 01:35:39 PM »
Pipe is $418.00
OK go on, make me a pipe then, cant have you not eating can we......
