Marque Remarks
British (BSA, Greeves, Triumph etc)
AJS 18CS piston
Topic: AJS 18CS piston (Read 2420 times)
211kawasaki
AJS 18CS piston
October 06, 2010, 10:25:14 am »
Does anyone out there have an idea where I can get an 86.5mm high comp piston for the 57 AJ? I dont want to put a JP, they havnt been that flash in the Velo and Im not sure that they even make the hi comp version.
Any help will be much appreciated as Im hoping to race at the masters games in a month.
Tanner #211
Re: AJS 18CS piston
October 06, 2010, 10:29:04 am »
Dave, give Frank Stanborough a ring.....he's the guru for those engines as you know. I'll PM you his #.
LWC82PE
Superstar
Re: AJS 18CS piston
October 06, 2010, 12:42:07 pm »
Im pretty sure ive had them from here
http://www.jp.com.au/JPPistons.html
also i get stuff from here
http://www.andrew-engineering.co.uk/
Andrew engineering is good, i get lots of stuff from them for AJS/MAtchless
http://www.russellmotors.co.uk/Classic%20bikes/classicbikes.html
Also you will find it handy to get in contact with the national AJS club, theres some real nutters on those models and will be able to answer all your questions and know where to get parts etc.
http://www.jampotdownunder.com/
Freakshow
Superstar
Adelaide, SA - looking for a "YZA" tank
Re: AJS 18CS piston
October 06, 2010, 02:46:25 pm »
Martin Adams - 0421874513
74 Yamaha flattracker's
70 Jawa 2 valve speedway's
For sale - PRE 75 Yamaha MX stuff, frame, motors and parts also some YAM DT1,2,A and Suzi TS bikes and stuff
211kawasaki
Re: AJS 18CS piston
Reply #4 on:
October 18, 2010, 12:08:55 pm »
Thanks guys, the Mighty AJS lives again and ready to run at the Masters Games.
Was a bit lucky really, the piston was cracked and rings were broken but I got it before it let go - and it wasnt far away from that!
211
Freakshow
Superstar
Re: AJS 18CS piston
Reply #5 on:
October 18, 2010, 01:16:52 pm »
Sweeet. where did you end up getting onto the new bits from > au or OS
Marque Remarks
AJS 18CS piston
