Author Topic: Maico 326  (Read 9739 times)
Offline Maicojames
Maico 326
« on: January 07, 2008, 06:51:47 AM »
http://cgi.ebay.com.au/Maico-MC250-326-big-bore-kitted-VMX-AHRMA_W0QQitemZ220188823369QQihZ012QQcategoryZ102690QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
This bike is so cool I don't know where to begin, I love the laydown conversion, looks like a 75 with 76 travel.
Firko, or any one can you explain what a 326 is? Is it a 400 barrel on a 250 lower end or???
Thank you,  James
« Last Edit: January 07, 2008, 10:59:51 AM by Maicojames »
Life is suddenly very Monaro
Offline paul
Re: Maico 326
« Reply #1 on: January 07, 2008, 09:10:53 AM »
james the bikes owner is a member on the forum im sure he will let you know .my guess is a sleeve and piston
Offline Wombat
  • Gold Coast hinterland
Re: Maico 326
« Reply #2 on: January 07, 2008, 10:18:42 AM »
I remember this one from the classies on this site; it was listed a few months ago and I attempted to buy it.
By the time I noticed the ad the owner had a change of heart and decided to keep it.
Great looking bike!
"Whadaya mean it's too loud?! It's a f*ckin' race bike!! That pipe makes it go louder - and look faster!!"
Re: Maico 326
« Reply #3 on: January 07, 2008, 10:22:59 AM »
The 326 is created by fitting a 76mm 400 top end to a 70mm stroke bottom end. The end result is a beautiful, tractible oversquare Maico that will beat any 400 or 440 in most situations. Anyone who's ridden or seen my 350 (326) Maico square barrel will know what I mean. The conversion started as a backyard mod but in the late 80s the factory introduced a 320 enduro that was a hidden gem.
Re: Maico 326
« Reply #4 on: January 07, 2008, 10:47:48 AM »
Hello all,
It's my bike and I no doubt will regret selling it but I plan to have a go on Husqvarna for this season. This bike was not built by me and has a 400 piston fitted to the standard non-decompressor, 7 fin 250 cylinder. You can't tell by looking that it is no longer a 250, but anyone who has seen it and heard it knows that something different is lurking underneath. Loses a little bit to the big bores down the long straight at Ravenswood, but makes up for it in the corners with handling and rideability. Super reliable and you only have to look at the kick starter for it to start. I am told it was originally built by Stackers many years ago. It is the correct front guard by the way. Every time I talk about it I think that I shouln't sell it, so I'd better stop now.
Offline Maicojames
Re: Maico 326
« Reply #5 on: January 07, 2008, 10:58:30 AM »
BigK, no offense intended on the front gaurd. It is a 75, I was looking for the more rounded 76-78 style. Extremely cool bike. I like the looks so much, I want to build one like it when I can.
Thanks for the info on the conversion..so it seems a 400 liner in a 250 cylinder.
Do you retain the 250s trans and primary? It seems these ratios would be lower, and that may make a difference on top end. Very, very cool.
Re: Maico 326
« Reply #6 on: January 07, 2008, 11:31:12 AM »
Bottom end is all 250. I run 13/54 final drive which allows me to hold 3rd in most corners and 3rd gear start on concrete gate, 2nd in the dirt. 13/56 is probably better overall, but knocks the top end off a tad too much for Ravenswood straight (my local track). It pretty well gets all its power to the ground which is what makes it so rideable, turns better than my modern bike.  I've gotta stop talking about it or I'll change my mind again!
Re: Maico 326
« Reply #7 on: January 07, 2008, 11:41:36 PM »
I was under the impression the 250 barrel could simply be bored out to suit the 400 piston as their was enough meat in the sleeve. A good mod once you run out of oversize choices.
Re: Maico 326
« Reply #8 on: January 09, 2008, 01:38:14 PM »
Bike has been sold to a forum member, he will have some fun on it for sure. Lookout everyone in Brisvegas.
Offline Maicojames
Re: Maico 326
« Reply #9 on: January 11, 2008, 02:44:36 AM »
Ok, Firko now I am gonna ask too many stupid questions( yes even more thna I normally do)-since I may have a lead on an AW250 engine.
Can you actually just bore the 250 liner to 76 mm?, if not do the ports in the 400 liner match, or do you need a blank of some sort? Is porting required or recommended?
I know an RM 370 piston can be used in a 400, can it also be used here?
Do you change the rod? What rod bearing etc? Must the 250 head be machined?
Base gasket used is 400..or modified 250?
Pipe would be a 400 pipe cut down to shorter length head pipe? ..250 pipe? custom pipe.
All internal 250 parts remain? Primary gearing, 2 row chain, etc-then would it be geared like a 400? Big K said he runs 13/54. I ran 14/56 on my old 440-is this eqivalent?
Demanding aren't I?  ;D ;D
Thank you for any replies,  MJ
« Last Edit: January 11, 2008, 05:55:53 AM by Maicojames »
Offline T250K
Re: Maico 326
« Reply #10 on: January 11, 2008, 06:02:17 AM »
 Yep, me too please Firko, same questions as Maico James.  I know nothing about Maicos only what I've picked up on the forum but am working toward getting a 250 from somewhere around 1979 - 81.  Can the same 326 conversion be done on the later engine ?     Cheers,     T250.
Offline paul
Re: Maico 326
« Reply #11 on: January 11, 2008, 06:21:15 AM »
today im going to stacker motorcycles  who apparently built the engine  so i will ask  ok james
Offline Wombat
Re: Maico 326
« Reply #12 on: January 11, 2008, 07:23:52 AM »
I'm the lucky bloke who bought the Maico 326 so any history/info will be appreciated ;D.
I mentioned earlier I tried to buy this same bike back in August; so I was stoked to score it this time around.
Thanks James for listing the ad or I wouldn't have known; so if you do make your way to Oz for an event you're guaranteed the 326 for the meet, OK? ;)
Offline Maicojames
Re: Maico 326
« Reply #13 on: January 11, 2008, 09:03:04 AM »
That's too cool of you. In the meantime I am dreamign of building a 326, like a 76 AW......nickeled frame, alloy swingarm, orange plastic(not available)-polished hubs and rims...I can dream....I can probably though get the engine going this spring.
« Last Edit: January 11, 2008, 11:16:08 AM by Maicojames »
Re: Maico 326
« Reply #14 on: January 11, 2008, 11:07:04 AM »
There was one of these Maico's at CD2. It was featured in VMX mag.15 page 55
I built a pipe for him which was just a standard 400 pipe.
A 400 pipe would help with more torque & bring the revs down a bit.
You could probably run a 250 pipe also if your like your bikes to rev more like a screamer
