Author Topic: TM125L Parts  (Read 579 times)
Stewy138
TM125L Parts
« on: May 05, 2010, 08:09:34 pm »
Parts avail from a TM125L (1974):
Front hub and backing plate (both good, brake plate stripped and ready to powder coat, brake arm zinc plated): $50 for both
Shocks - 345mm - not original, need a rechrome, rebuild: $50
Forks - fork tubes, springs, damper rods and caps all good.  One only stanchion, rusty, may be rechromable not sure.
Triple clamps (good) $50
Carby (28mm), needs a good clean $45
Oil pump, looks ok but working condition unknown: $30
Barrel: in good condition but has been over-ported - the transfer ports have been taken out too far.  $20.
Seat base - rusty but would be ok to use as a template to make a new one: $10
Swingarm bushes - 2 x plastic (09307-18001) and 2 x zinc plated metal inserts (61251-28000): $30
Footpegs - zinc plated, look great
Crankshaft - rusty but not in the areas of the bearings/seals, would probably clean up ok: $25
Will discount for multiple items,
Plus postage from Brisbane.
Offline brent j
Re: TM125L Parts
« Reply #1 on: May 05, 2010, 08:16:03 pm »
I'll gladly take the swingarm bushes off you . I'll be in Brissy for the QLD champs and CD7 so will collect them then.
Brent
