Marque Remarks
Suzuki
rm125 model
Topic: rm125 model (Read 1891 times)
zman
rm125 model
January 18, 2010, 12:13:36 PM »
g day all i may be able to buy an rm125 its either an x,z model i cant tell the difference its all complete but not running.what do they go like is one model better than other. are parts hard to get for them. cheers
DR
Re: rm125 model
January 18, 2010, 02:47:26 PM »
this 125X just went up to Ray in central QLD. It's stock apart from the aftermarket front guard and the DG exhaust. Dodgee built this bike from parts basically so the bits are out there if you hunt around. I don't imagine there would have been a great difference between the x and z only to say maybe the Z was a little more refined. good luck, I reckon the Z model in all capacities look the ducks nuts
clickable image
TM BILL
Re: rm125 model
January 19, 2010, 08:08:32 AM »
Most notable difference is Z went to full cylinder reed induction where X is case reed induction
Marc.com
Re: rm125 model
January 19, 2010, 08:11:22 AM »
X was prone to head leakage and Z wasn't. I think later Z motor is better bet.
RMJJ
Re: rm125 model
Reply #4 on:
January 19, 2010, 08:54:08 AM »
I think the x is a far superior bike to the z. The x defo had the much stronger engine.
Parts are still around but getting rarer
New bike anyone ?
http://forums.mxtrax.co.uk/showthread.php?t=262448
suzuki43
Re: rm125 model
Reply #5 on:
January 19, 2010, 10:58:50 AM »
Yes i concur with JJ the x motor is way better than the Z or D.I have owned both the X and D so I guess I should know.Like Doc said the parts are out there......
zman
Re: rm125 model
Reply #6 on:
January 19, 2010, 05:12:16 PM »
so why was the x prone to head leak then. cause if it is an x model. is the problem bad enough not to buy it or would a z head bolt on and fix it or even go with the z barrel to
TM BILL
Re: rm125 model
Reply #7 on:
January 19, 2010, 06:09:36 PM »
Quote from: zman on January 19, 2010, 05:12:16 PM
Thatall work
X CASE REED Z FULL REED
DR
Re: rm125 model
Reply #8 on:
January 19, 2010, 06:24:27 PM »
Bill, I've just noticed your massive tits..very nice
TM BILL
Re: rm125 model
Reply #9 on:
January 19, 2010, 09:55:32 PM »
Thanks Doc
ill try and get em to come to CD7
Marque Remarks
Suzuki
rm125 model
