Clubroom => Tech Talk => Topic started by: bazza on May 13, 2020, 02:53:29 PM
Any body know spring weight for standard CR250M. I Need to go stiffer but not sure what std CR is
Not what you asked but have you had a look at the racetech spring calculator? Put in the brand/model/year and it will bring up a page that lets you use the calculator.
https://racetech.com/ChooseVehicle.aspx
Thanks Ralph have seen that - but need to compare those to what ever standard rate is, Cheers
any one? or contact for a CR250M guru who may know
