Clubroom => Tech Talk => Topic started by: suzuki447 on August 13, 2018, 07:04:31 PM
hi guys i have set of GEM reed valves for a tm125.before i install does anyone know if i have to change anything to use them e.g. bigger carb,jet etc.any info would be helpful.thanks in advance.don
don't know about jetting changes but you need to drill 2 holes in the intake side of your piston to make use of the reed valve,some one on here will have details of where they need to go
cheers matt.
do a search for Suzuki tm125 gem reed valve on ebay a seller has 1 for ts125/185 which would be similar to yours,maybe he'll send you details of the piston mods needed
